Power Store 3
Thread begun 7/09/2010 2:39 am by graham394789 | Last modified 7/18/2012 9:44 am by Jason Byrnes | 2496 views | 5 replies |
graham394789
Power Store 3
I have just purchased Power Store 3 and am fully aware that it supports only one currency but wish to change the currency prefix to R for Rand instead of $. Please advise where i might find the Variable definition in order to do this
Many Thanks
Graham Page
South Africa
Like you noted the currency update is not something that is fully supported but there is a PDF document that details how you can do this. It might not cover every occurrence of the currency symbol but the basics that are covered should help you.
ps_changing_currency.pdf
graham394789
The document help to change all the dollar signs except the ones on the home page of the featured product and the popular product. changing the code on the home page itself does not translate to the php generated products. Any suggestions? Again many thanks.
In the default index.php file these dollar signs can be found on lines 175 and 211. The lines start like this:
<h4>$'.
This is the dollar sign that you need to remove.
daniel387105
Ok thanks, i have changed the $ to £ on the index page but when i view live its still showing $. also i could use some help with the Products_Detail.php page as im not sure what to change?
Also do i need to change the pages cart.php
confirm.php
Admin/Products_Results.php
Admin/Products_Update.php
Admin/Products_Detail.php
This is not a supported modification to Power Store 3. Power Store 3 does not have support for changing the Currency.
