verification emails
Thread begun 7/01/2010 2:20 am by i.edwards384429 | Last modified 7/09/2010 10:53 am by Eric Mittman | 5437 views | 12 replies |
i.edwards384429
verification emails
Hi
thought I'd sent this already
Using the user registration pack I'veset up UK spec and five file uploads which all work.
However the userverification email seems to have stopped working since I set up file upload using UE4.
The files are attached and the mail_php.php does include the -f switch which my host requires.
Any ideas why it.s not working?
thanks
Ian
i.edwards384429
update
Hi
forgot to say that the users_emailPW.pp page works perfectly the reminder email is received in seconds.
Ian
That is good that you are not having any problems with the other email. The UE server behavior that you have on this page looks like it is configured properly to me. Are you getting to the users_ThankYou.php that is specified as the redirect? If so the code for the email should be getting executed. As a test you should try copying the Universal Email server behavior and include lines to a new blank page and then copy over the form from this page.
If the message will not send with just the UE and the form on the page then it would indicate a problem with the UE server behavior, otherwise it is probably a conflict between the other server behaviors that are on the page.
i.edwards384429
Update
Hi Eric
back from the UE forum.
I created a gmx account as you did and registered and it all goes through to the thankyou page no problem but no verification email is received.
If I register using a me.com then registration confirmation is received.
If I try using gmx.co.uk or edwards-micros.co.uk or o2.co.uk nothing is received although all database information isa written.
I've tried adding the co.uk to the email formatting file but that makes no difference.
I'm now at a loss as to what direction to go in as it appears the script works but only on .com
This all went wrong when I saw exclamation marks in the server behaviours telling me it was an old version of UE. Since then it hasn't worked
Any ideas?
thanks
Ian
thanks
Ian
i.edwards384429
update
Hi
used the css form maker and created a form, used ue4 fto finish of and then sent it to my server.
I can from this test form send emails to .co.uk
I then compared both webassist directories both check out as identical.
Seems to be some issue with the user registration pack but I cant see what.
Cheers
Ian
i.edwards384429
update
Hi
been playing over the weekend and think I'm just going mad.
register from a .com from any PC and the verification is received.
Send from a .co.uk and no email, so the script must be valid?
if you want to check my insanity try this
users_Registration.php
it's not on line yet
thanks
Ian
I did a test with a default setup of the URSP and found that I can register with my gmx.co.uk address without issue. In the link that you provided I cannot get the form to submit, it hands on the phone number. Do you have an example number that I can use to get past that?
There is nothing in the URSP or the new version of UE4 that will prevent emails from getting sent to co.uk addresses.
i.edwards384429
update
Hi eric
As the site is predominently aimed at Uk that is probably why it wont take US numbers - something I need to consider-
try using 02345678910 for phone number and bs227qu for the postcode.
I've just tried it again and .co.uk are just not delivered
really weird
thanks fopr the assist
Ian
I'm not able to pass the phone validation regardless of the values that I enter. Are you able to register with the form? If so what are the values you are using? In all of my testing there is nothing that is limiting .co.uk email addresses.
Do you have a default version of the Registration Pack setup? If so have you tested with this one? The code that we produce in the Solution Packs and with UE will not prevent emails from being sent to .co.uk addresses.
i.edwards384429
update
Hi Eric
When I used the basic user registration package the emails worked once Jason had helped add the -f switch.
the problem only started when I purchased UE4 and added upload fields. In the server behaviours was a red exclamation with the message "old version" .
On the forum Iwas advises to double click which I did and the exclamation mark dissapeared. I then used UE4 to setup the uploads.
Since then no validation emails have been received. On the forum I saw other with a similar issue so tried it with my .me.com account and validation was received.
At that point I decided to plead insanity ;-)
As to your filling the form in, in my tests I can see I've filled it in 82 times with a sucessfull submission to the database. However since adding the upload no .co.uk emails are received - cant say about any others I have not tried.
I've attached two screen dumps of what I fill in to test.
I've also registered from PC's other than mine in case mine was throwing a wobbly
really sorry to be a pain but I do not know whats left to try.
cheers
Ian
