Binding dynamic data into email
Thread began 6/24/2010 8:13 am by christina.elissa4324782 | Last modified 1/21/2011 12:44 pm by Jason Byrnes | 4663 views | 18 replies |
I am creating a registration form that is being inputted into a database. Two of the fields are being created from record sets and being inputted into other relational tables in the database using the manage relational tables function. I also want the form to be emailed to the person filling out the form. The results in the email that I am getting are:
WADA RepeatID sessionId 0: 1
WADA RepeatID sessionId 1: 2
sessions 1: 2
WADA RepeatID sessionId 2: 3
sessions 2: 3
WADA RepeatID sessionId 3: 4
sessions 3: 4
WADA RepeatID sessionId 4: 5
sessions 4: 5
WADA RepeatID sessionId 5: 6
sessions 5: 6
WADA RepeatID sessionId 6: 7
and
WADA RepeatID groupId 0: 1
WADA RepeatID groupId 1: 2
WADA RepeatID groupId 2: 3
WADA RepeatID groupId 3: 4
WADA RepeatID groupId 4: 5
registeredGroup 4: 5
WADA RepeatID groupId 5: 6
WADA RepeatID groupId 6: 7
WADA RepeatID groupId 7: 8
WADA RepeatID groupId 8: 9
Insert: Insert
WADAInsertRecordID:
How can I get them to list as an array using the names rather than the id number (Sessions: Session 1, Session 2, etc.)? The numbers are needed of course for the input into the relational tables; Is it possible to do a record set to get the information I need and bind it?
Thank you in advance.
Also, how can I have it not include the Insert button or the Insert Record ID?
Christina
Are you using one of the default mail templates? If you are, all the posted values will be input into the email. If you want to customize the email yourself, you will have to uncheck the generate email with template and click to edit the email. Then you will be able to bind the different values you want onto the email and also bind recordset values to the email, so you can use the name instead of the id.
I am editing the template for the email. I grabbed the mysql select statement from the results page (created with data assist and manipulated for my needs):
$ParamattendeeId_WADAattendee = "-1";
if (isset($_GET['attendeeId'])) {
$ParamattendeeId_WADAattendee = (get_magic_quotes_gpc()) ? $_GET['attendeeId'] : addslashes($_GET['attendeeId']);
$ParamSessionattendeeId_WADAattendee = "-1";
if (isset($_SESSION['WADA_Insert_attendee'])) {
$ParamSessionattendeeId_WADAattendee = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_attendee'] : addslashes($_SESSION['WADA_Insert_attendee']);
$ParamattendeeId2_WADAattendee = "-1";
$ParamattendeeId2_WADAattendee = (get_magic_quotes_gpc()) ? $_GET['attendeeId'] : addslashes($_GET['attendeeId']);
mysql_select_db($database_ifpaDataBase, $ifpaDataBase);
$query_WADAattendee = sprintf("SELECT attendee.attendeeId, CONCAT_WS(' ',salutation, firstName, middleInitial, lastName) AS name , rankService, positionTitle, company, street, street2, city, stateCountry, postalCode, phoneNumber, faxNumber, email, payBy, paid, GROUP_CONCAT(sessionName SEPARATOR '; ') AS sessions FROM attendee LEFT JOIN attendeeSessions ON attendeeSessions.attendeeId = attendee.attendeeId LEFT JOIN sessions ON sessions.sessionId = attendeeSessions.sessionId WHERE attendee.attendeeId = %s OR ( -1= %s AND attendee.attendeeId= %s) GROUP BY attendee.attendeeId", GetSQLValueString($ParamattendeeId_WADAattendee, "int"),GetSQLValueString($ParamattendeeId2_WADAattendee, "int"),GetSQLValueString($ParamSessionattendeeId_WADAattendee, "int"), GetSQLValueString($ParamattendeeId_WADAattendee, "int"),GetSQLValueString($ParamattendeeId2_WADAattendee, "int"),GetSQLValueString($ParamSessionattendeeId_WADAattendee, "int"));
$WADAattendee = mysql_query($query_WADAattendee, $ifpaDataBase) or die(mysql_error());
$row_WADAattendee = mysql_fetch_assoc($WADAattendee);
$totalRows_WADAattendee = mysql_num_rows($WADAattendee);
I did have some errors in the sql, but I fixed them and am still not getting an email
have I done something incorrectly with using this code? I'm connecting to the database fine, the information is being inserted into the database correctly. It's just not emailing.
Where did you add this code to? Is it on the email template itself or is it on your form page?
If you could zip up and attach the email template so I can take a look at it, that would be great.
Here is the template file. Thank you for your help.
ifpaConferenceRegistration.php.zip
I don't see any issues with the email template, so it might have something to do with the query not returning any results. Have you tested the query directly in your database?
because the query is based off a session, it's difficult.
I have replaced:
WHERE attendee.attendeeId = %s OR ( -1= %s AND attendee.attendeeId= %s) with WHERE attendee.attendeeId = 1
or some other id # and I get results on the web page.
Could there be something wrong with the way I'm calling the session? I have included the registration page as well in case there is something there.
attendee_Signup.php.zip
It looks like the session variable is being set up correctly to me. Its possible that the session is getting cleared somehow when it is going to the email page.
In the waue_attendee_Signup_1.php page (created when doing the universal email) there is a session named "waue_attendee_Signup_1_Status" referenced twice. My session that is grabbing the data in the template page is "WADA_Insert_attendee". Should one of these be changed? What can I do to get the session in the email template if it is being cleared?
Are you using these different session variables to hold the same value? Only if you are holdig the same value in these session variables should you update the entries for them all to be the same.
What is the current result that you are are getting? Is your recordset returning the rows that you need, what are you getting in the email message now with this?
