Removing the security question
Thread begun 5/31/2009 8:31 am by warrenphillips25336771 | Last modified 6/09/2009 12:59 pm by warrenphillips25336771 | 4175 views | 6 replies |
warrenphillips25336771Beta Tester
Hey guys
So I have built one site using the solution, then the guy says hey i want the same , but in spanish, so i get to this, how do i remove the security question below the captcha, as i can't convert this to spanish ( and i don't want to neither). I have huffed and puffed but can't find no documentation on this issue.
Would it be possible to just use the age old html <!-- --> or not?? please can someone let me know.
thanks
warren
Jon GibsonBeta Tester
Removal of Security Question
Hey Warren:
In the default contactus.php file (with no other code) the second security question is on line 337. You would need to remove from line 337 to line 349. That should do it.
You may want to also remove the $WAFV_Errors validations:
line 18 in the unchanged contactus.php file.
Hope that is what you were looking for.
thanks john I will attemp to change it, I did add a few things but will be able to look for it
HI
Ok, the contactus.php page it does not go to line 337. I am getting desperate now to get this security question removed, I have removed some stuff but it does not send through, so can someone please help, or WA even give some documentation on how to change these things.
thanks
I need to know everything to take off please, I will compare the original to the modified one i am doing.
thanks
warren
Neil Beadle
How to remove Captcha and Random Question
We have just finished creating the How To for removing the Captcha and random question security features from the Contact Form Solution Pack.
You can access this How To from the Contact Form Solution Pack Support page at this link
contact-form/
thanks neil greatly appreciated
