Rollover information
Thread begun 6/14/2010 3:08 pm by Miguel | Last modified 6/15/2010 9:07 am by Jason Byrnes | 1280 views | 1 replies |
Miguel
i made a line dot graph with dynamic data, where i select on X value date by months, and then i select count the id of users to display the total of them and then i selected the show multiple dataset from column so far so good when i check my graph it display the months that had subscriptions on the site with several lines with dot with difrent colors by the countrys that the users had selected and the dataset displays each country with it color, ok nice so far, now i had 2 countrys that had the same amount of registrations on a same month like 1 from canada on june and 1 from australia on june, when i place my mouse over the dots it displays a dot black souranded by blue wich is each color of the country but the tooltip only displays 1 how can i make the tooltip day (1 from canda) (1 from australia) instead of the month (june 2010 1) i try out tip and tooltips but have no idea how to accomplish this it alwas displays only 1 value.
Also i try to do the tutorial to add 2 dot graphs in one but the dates get unordered why would that be?
thanks
Sades
This is a limitation to the Open Flash Charts API that is used in Dynamic Web Charts.The Open Flash Charts API does not offer a way to handle two points that intersect.
