ribbon_fullsize
Thread begun 5/31/2010 9:11 am by CraigR | Last modified 6/01/2010 1:28 pm by Jason Byrnes | 1421 views | 3 replies |
CraigRBeta Tester
ribbon_fullsize
what is the best approach for changing the fullsize image with this gallery style ?
i have changed several elements of common.css, but the full size image remains the same size at 782px
in the alaries/ribbon_fullsize/index.php file look for the following:
$gallery = get_gallery(get_mediarss_url('gallery=' . $pg_id . '&thumb=62c&full=782p'));
the "full=782p" tells the gallery to use the 782 proportional image that is defined in the Admin/common/properties.php file
you can change that to use one of the other proportional sized images:
$gallery = get_gallery(get_mediarss_url('gallery=' . $pg_id . '&thumb=62c&full=163p'));
or one of the cropped images:
$gallery = get_gallery(get_mediarss_url('gallery=' . $pg_id . '&thumb=62c&full=132c'));
If none of the sizes meet you needs, you can add a size to the properties.php file, then regenerate the images by updating the watermark to recreate the thumbnails.
CraigRBeta Tester
Thanks Jason - that's just what i needed.
No worries, glad you have it working.
