Show Product Quantity and Sales
Thread begun 5/28/2010 8:13 am by psychobilly1165508 | Last modified 5/28/2010 12:03 pm by Jason Byrnes | 2222 views | 3 replies |
psychobilly1165508
I'm trying to create a chart that shows the individual product sales.
I'm using the standard "orderdetails" table with eCart.
I've tried:
X Label "DetailItemID" group by value
Y Label "DetailPrice" calculation SUM
which shows a chart with the productID.
I tried selecting "show multiple datasets from column" but the chart says "undefined"
How do I get the product name instead of the ID?
you would need to modify the recordset that is created to Join the products table to the order detail table to return the product name.
look in the dynamicwebcharts/data folder for the data file it will use the page name it is attached to in the name:
<pagename>_data1.php
send a copy of this file along with the name of the ID and Product name columns from your product table and will help you modify the recordset.
psychobilly1165508
I think I figured out the problem.
The custom recordset works, but the product names have "quotes" on some items. I assume this is causing problems for the flash chart?
yes, quotes will cause issues in the flash chart.
you could use str_replace() to replace the quote"'" with "&quote;" instead
function.str-replace.php
