Extension update
Thread begun 5/26/2010 1:03 pm by balexander389215 | Last modified 5/27/2010 8:57 pm by balexander389215 | 1681 views | 2 replies |
balexander389215
Extension update
I have been updating the extensions as they become available. Site import extension was just released an I went through the update procedure, only this time I received the message, "A newer version of file ... already exists. Do you want to replace this."
I assumed I was to say no since I had just updated some other extensions and I didn't want to mess one of those up by replacing newer files with older files. To my chagrin I discovered there are 1,461,253 files to be replaced, ... well it felt like that many after clinking no for 10 minutes.
What is the proper procedure for upgrading these extensions? There will be several more to do and I expect I'll be running into this problem again.
neilo
Hello there,
The correct procedure is to click the option to overwrite them all. The new files (regardless of date) are duplicates of files they will replace (mostly button image files, I believe) - so one click should be all you need.
This goes for any extensions you need to install/reinstall.
balexander389215
Thanks very much, I appreciate the info. It will same me a lot of time on updates.
