Duplicate entry '11' for key 2
Thread begun 5/20/2010 6:54 am by gjdunn405023 | Last modified 5/25/2010 6:25 pm by Eric Mittman | 3382 views | 7 replies |
gjdunn405023
Not sure what this means. Recently changed an URL variable (result is "11") but don't see where the problem is, or what "key 2" is.
Any thoughts appreciated.
Please explain a little about when you are seeing this error and what exactly you have changed and what it was before.
This error usually means that you are trying to specify an id during an insert that already exists in the db.
gjdunn405023
Thanks for the response. Gawd I'm confused.
That error is gone (not sure what I did). Now when I try to Login from any page I get a new error: "Table 'globalmix.users' doesn't exist".
"globalmix" is my site, but I've searched the entire site with no results for 'globalmix.user'
Any thoughts appreciated, as always.
Regards,
Normally a message like this is referring to the db and table name: globalmix.users. Are you getting this error locally or on a live server? What is the name of your db? What page are you getting this error on and when does it occur? Please post back with this info and a copy of the page in question.
gjdunn405023
Thanks again for the response - great support!
I'm using Dreamweaver and Navicat. My local site is connected to my testing server. I have 2 databases: GlobalMix (for dynamic pages), and GlobalMix2 (for UserRegistration services). Neither one of them has a table with that name.
My originating page is "206.130.43.10/UserRegistrationGM/users_LogIn.php"
And when I hit Login, it shows as "206.130.43.10/UserRegistrationGM/users_LogIn.php?" with the error message.
What format would you like the pages in?
Regards.
It sounds as though the two different db connections are getting confused. The error is telling you that it can't find your users table in the globalmix db. This seems correct based on what you have posed here since the users are part of the registration setup and those tables are in the GlobalMix2 db.
Do you maintain two different connection files for the site? If so it seems that you have one referenced after the other and the db that are being used are getting mixed up. You need to ensure that the connection to GlobalMix2 is included just before any of the user related code. If the wrong include is being referenced you will receive an error like the one you mentioned.
Do you have a requirement to use both databases for this? It is not conventional to have more than a single db referenced in a site like this unless there is a specific need for it. What happens if you combine the db's?
gjdunn405023
Is there some way to contact you offline? I would like to send a copy of my "localhost.php" file for questions.
Regards
I have opened a ticket for you on this issue so that we can exchange some more info in private. To update your ticket login and visit your support history.
