Slideshow Dissolve Resizing Issues
Thread begun 5/07/2010 6:59 pm by elevy388997 | Last modified 5/11/2010 9:46 am by Justin Nemeth | 2841 views | 5 replies |
elevy388997Beta Tester
Hello,
On two sites I am having problems with my gallery:
Gallery.html
www.levycommunications.com
I followed the instructions here showthread.php?t=10969 and for the levycommunications site, it didn't seem to do anything...the jtstitches site just got all messed up.
After updating the admin properties file and gallery index file, I re processed the images for "new watermarks" and that was my results.
Justin Nemeth
It looks like the same issue as the above thread that the images need to be created triggering the new size to be created. What does your properties.php file look like?
This is for the levycommunications.com site. The 700 x 475 is what I need to work.
$GLOBALS['image_extensions'] = array('png', 'jpg', 'jpeg', 'gif'); //use lowercase
$GLOBALS['resize_proportional'] = array(
array('w' => 1024, 'h' => 768, 'watermark' => true),
array('w' => 782, 'h' => 481, 'watermark' => true),
array('w' => 700, 'h' => 475, 'watermark' => true),
array('w' => 163, 'h' => 92)
$GLOBALS['resize_cropped'] = array(
array('w' => 62, 'h' => 62),
array('w' => 132, 'h' => 140),
array('w' => 102, 'h' => 102),
array('w' => 42, 'h' => 42),
array('w' => 999, 'h' => 260, 'watermark' => true)
$GLOBALS['jpg_quality'] = 90; //0-100, 100 being the best
$GLOBALS['png_quality'] = 1; //0-9, 0 being the best
$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
Too bad there isn't a size W x H setting in the admin control area.
Justin Nemeth
Your page needs to look for 700p but you have 450p which is an invalid size based on your settings above. If you change it to 700p it should work.
Can you please bold this area as I do not see what you mean when you say I have 450p
Justin Nemeth
It would be the url you specify on the index.php page for your gallery, around line 12 or so. That url is where the image size is specified, and it must be set to 700p instead of 450p.
