Showing images in basket/checkout
Thread begun 5/01/2010 9:09 am by glenn140201 | Last modified 5/03/2010 1:13 pm by Jason Byrnes | 3683 views | 8 replies |
glenn140201
Hi
I'm sure I'm missing something obviosus, but because I set up my initial cart not to show images in basket/checkout I can't seem to get them to show. I'm guessing this is because the image field in my cart view is not mapped to my database entry. How do I resolve this please.
Cheers
Glennyboy
First you need to add the image column to your eCart object.
Next you need to modify the add to cart buttons to store the image name for the product in the new image column, on the bindings tab of the add to cart button interface, select the image column, then click the lighting bolt next to value and select the image column from your recordset.
Finally, you need to add the image tag in the cart display:
<img  src="imagesupload/<?php echo $WA_Store_Cart->DisplayInfo("Thumb"); ?>" alt="" />
this example assumes that the images are stored in the imagesupload directory, that the cart is named WA_Store_Cart and the image column is named Thumb. You need to make any needed corrections.
glenn140201
Ah yes Jason of course it has to come from the add to cart.
I unfortunately have another error in my cart.
When I add an item to the basket it has started to simply replace the current items quantity and then adding to the price. The new item itself does not show. The ecart repeat region repeat seems to have stopped completely?
Can you please advise how to rectify this.
Cheers
Glenn
This will happen if the two items share the same id.
make sure the ID being added to the cart is unique for each item.
glenn140201
Hi Jason
Yes thanks I just noted the same and sorted it. When I updated the add to cart sb it defaulted to the wrong id from my list. I amended to the product ID and it works again now.
Thank you for your continued assistance.
Cheers
Glenn
glenn140201
Hi Jason
Regrettably the cart has now also lost my shipping, which also worked previously.
I have set a standard shipping for a set price per item of £4.99 as follows:-
total number of items > 0
Based on quan
Quan of item 1 x £4.99
Again I'd appreciate your input to get me taking payments asap.
Cheers
Glenn
This looks like it will only work if Item ID 1 is the cart.
Can you make sure you are using the correct product for testing.
glenn140201
Hi Jason
I want a set 'standard shipping' of £4.99 to be added for each and every item in the basket. - not just an item with ID of 1. So Q x £4.99.
To expand I have attached a screen-grab of my current settings.
I'd appreciate your direction.
Glenn
the calculation you are using, "Based on Quantity of an item" is specific to the ID you set.
you want to use the d"Based on column Subtotal" Calculation:
Subtotal of Column "Quantity" "Times" "4.99"
