Urgent HELP!! Form Giving Validation Errors..
Thread began 4/20/2010 7:38 pm by Wasntme | Last modified 4/21/2010 1:22 pm by Jason Byrnes | 4203 views | 15 replies |
Wasntme
Hi All,
Could some have a look at this form that I Created using CFB but its giving me errors and cant submit..
Sumo-Eform.php
the following are the that errors all the time..
Are you of Aboriginal / Torres Strait Islander origin? *
Do you speak a language OTHER than English at home? *
Do you require support from Guru training with language, literacy, numeracy and/ or guidance services?
Vin
Wasntme
OK I managed to get past that but I have a new issue.
The email I receive from the contactt form is missing all the yes / no answer.
SECTION A: EMPLOYER & PERSONAL DETAILS
Company Name: cxvxc
Family Name: vxcvxc
Given name: xcvxc
Date of Birth: 3242
Sex: Female
Address: rwerwe
Suburb: dsfsdf
Postcode: 324432
Home Phone Number: (012) 345-6789
Mobile Phone Number: 0123456789
Email: vinod@v-i.com.au
SECTION B: CULTURAL BACKGROUND
Country of Birth: dfgdfg
1. Please tick the box below that indicates your current status.:
2. Are you of Aboriginal or Torres Strait Islander origin?
3. Do you speak a language OTHER than English at home?
4. How well do you speak English?
5. Do you require support from Guru training with language, literacy, numeracy and/ or guidance services?
If Yes: support
SECTION C: DISABILITY
6. Do you suffer from any medical condition?
If Yes: Medi TEST
SECTION D. EDUCATION
7. What is your highest completed level of secondary school?
8. In what year did you complete that level?
9. Are you still attending secondary school?
10. Have you successfully COMPLETED any qualifications?
Qualification Title: cxvxc
Year Awarded: vxcvxc
Country/ State: xcvxc
SECTION E. EMPLOYMENT STATUS
Job Title: xvcxv
Employment Start date: cvxcv
Employment Type: Full Time
Average Hours Worked Per Week:_12 to 20_
If other:
some of your form elements have invalid names. for example:
<select class="formMenufield_Large" name="SECTION_B_CULTURAL_BACKGROUND_group_Do_you_require_support_from_Guru_training_with_language,_literacy,_numeracy_and_or_guidance_services"
form names can contain only letters and numbers. The only exception is the underscore character. this form element has a coma in the name.
CSS Form builder creates the name based on the label you give it, you should avoid using special characters or punctuation when crating a form element label.
Wasntme
Ok I have gone through the form and made sure there isn't any special characters or punctuation.
Still the same problem...
Wasntme
its 1:30 (aust time) in the morning and I need this issue to be fixed before 8:00..Please HELP... :(
please be as specific as possible so that I can accurately assess the issue. what field is not showing in the email?
Wasntme
From what I can see its all the ones with the drop down options in section B and D. I have copied the email i received at the bottom.
Please indicates your current status: *
Are you of Aboriginal or Torres Strait Islander origin: *
Do you speak a language OTHER than English at home: *
How well do you speak English: *
Do you require support from Guru training with language or literacy or numeracy and or guidance services: *
What is your highest completed level of secondary school: *
In what year did you complete that level:
Are you still attending secondary school: *
Have you successfully COMPLETED any qualifications: *
EMail
Company Name: xcvxcv
Family Name: cxvcxv
Given name: cxvxcv
Date of Birth: 4324
Sex: Male
Address: dfgdfgd
Suburb: fgdf
Postcode: 2344
Home Phone Number: (012) 345-6987
Mobile Phone Number: 9874563210
Country of Birth: dsfsdf
1. Please tick the box below that indicates your current status:
2. Are you of Aboriginal or Torres Strait Islander origin:
3. Do you speak a language OTHER than English at home:
4. How well do you speak English:
5. Do you require support from Guru training with language or literacy or numeracy and or guidance services?
If Yes: sdfdsf
6. Do you suffer from any medical condition:
If Yes: sdfds
7. What is your highest completed level of secondary school:
8. In what year did you complete that level:
9. Are you still attending secondary school:
10. Have you successfully COMPLETED any qualifications:
Qualification Title: sdfsd
Year Awarded: sdfsd
Country/ State:
Job Title: sdfsd
Employment Start date: fsfsf
If other: sfdsf
In Universal Email, you probably need to rebind those forms elements in the email message since the names have been changed.
When you first created the email message, the code to output the form values would have been created based on the old names of those elements. now that the names have changed, you will need to edit the email message and add new bindings for those form elements so the code will be generated based on their currant names.
Wasntme
Sure I will do that again.
THanks
Wasntme
MMM... still no luck.. This sections...
5. Do you require support from Guru training with language or literacy or numeracy and or guidance services:
Country/ State:
