When I update my file name is deleted
Thread begun 4/20/2010 10:50 am by jegoadby285710 | Last modified 5/25/2012 6:49 am by Jason Byrnes | 11459 views | 47 replies |
jegoadby285710
hi
The problem i have is when i use the update function the filename is deleted laving no link to the uploaded doc.
I have used this in the past with no real problems at all and I have looked hard at the code but can not see any obvious errors.
Iv attached the file in question.
Any help is most welcome
Employment_Profile_a.php
Kind regards
John
arista341524
Having similar problem
I think I'm having a similar problem, although I might just be using the software incorrectly. My page is supposed to be updating a database record which feeds a photo file name to the database. The update function works fine, but you MUST re-upload a photo each time, or else it deletes the previous photo record. I know there's a solution here, but I can't find it.
Thanks...
arista341524: The default file field must not be set for you. If you are updating, you are getting the value of the original file name in a recordset. You will have to bind the original name (stored in the database) to the default file name.
jegoadby285710: does the value get erased every time or just when you don't upload a file?
jegoadby285710
Originally Said By: Jimmy Wu
Hi
It only gets deleted when i dont upload a new file. Problem is I'm sure i'v set up the defalt file name field correctly i.e. bound it to ha hidden field with a value of the original file name from the data base i know this to be correct as iv tested the record to see if its retrieving the name.
Iv attached the php page
Any help is very welcome
Kind regards
John
jegoadby285710
Originally Said By: arista341524
Thanks...
Hi
There is a default file name you can set, unfortunately this is the problem I'm having at the moment. It allows you to maintain the original file name unless you decide to upload a new one and saves having to upload the same file evey time you update any other records.
Kind regards
John
in the code, the default file field is linked to the textfield form element:
'DefaultFileName' => "".((isset($_POST["textfield"]))?$_POST["textfield"]:"")  ."",
your hidden form elemeent that contains the origianl file name is not named textfield, it is named cvv:
<input name="cvv" type="hidden" id="cvv" value="<?php echo $row_WAATKEmployment['Employment_CV_name']; ?>" />
change the default file code to:
'DefaultFileName' => "".((isset($_POST["cvv"]))?$_POST["cvv"]:"")  ."",
jegoadby285710
Still not working
Hi Jason
I have changed the code and its still not saving the name.
I really have gone though this with a magnifying glass but just can not see any obvious mistakes.
Thanks for looking.
Any suggestions most gratefully received.
Best
John
ok, to trouble shoot, change:
$WA_redirectURL = "View_Profile.php";
to:
$WA_redirectURL = "";
so that the page will not redirect after the update
then add the following code in the body tag:
if($_SERVER["REQUEST_METHOD"] == "POST"){
echo(
"SQL: "$WA_Sql."<br />");
echo(
"default file:".((isset($_POST["cvv"]))?$_POST["cvv"]:"")."<br />");
echo(
"Debug Info:<br />"WA_DFP_AllUploadsDebug());
post the results of this code after testing and a new copy of our page.
jegoadby285710
Results of test
SQL: UPDATE `Employment` SET `Employment_Full_Name` = 'John Goadby', `Employment_UserName` = 'johngoadby', `Employment_Password` = 'j12345', `Employment_Adres_Hous_No` = '37', `Employment_Adres_Street` = 'Barwell Road', `Employment_Adres_Town` = 'Suffolk', `Employment_Adres_County` = 'Suffolk', `Employment_Adres_Post_C_Zip` = 'IP33 1AF', `Employment_Country` = 'UK', `Employment_Eamil` = 'jegoadby@mac.com', `Employment_Mobile` = '07752830118', `Nokia` = 'N', `Ericsson` = 'N', `Alcatel` = 'Y', `BTS` = 'N', `Microwave` = 'N', `Employment_CV_name` = '' WHERE `Employment_pk`=11
default file:
Debug Info:
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
login.php
