Change map size after creation
ProMaps: I created a map, then decided I want it larger. Just resizing the DIV does no good - I still see the original map size of 200x200 in the upper left corner of a gray box that's my new size of 650x400.
If I don't enter any coordinates, the default google USA map fills the entire div - it's only when I enter an address or use Lat/Lon - looks like only one tile will load, and always in the upper left. I also noticed that when the page first loads, the entire map is there - but after the map loads fully, only the one tile displays.
The pin and text balloon show up in the gray area as the map is scrolled - just no map!
Works fine in FireFox - the problem appears to be in IE 7 and 8 - tried them both.
Any suggestions?
