some error
Thread began 4/09/2010 11:58 am by info316330 | Last modified 4/12/2010 7:55 pm by Eric Mittman | 496 views | 3 replies |
info316330
some error
in server behavior I try to set:
wa utilities > set server timeout
but I receive this:
Dreamweaver
Si sono verificati i seguenti errori JavaScript:
Impossibile aprire il file di script "C:\Programmi\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\DigitalFilePro\Library\WA_UserInterface.js" (errore 3).
OK
I try so to delete .dat file but the error is the same
How ca I resolve?
Thank
If you have taken the steps to delete the cache file and still have this problem there might be a corruption of your configuration folder. Here is a link to a post with steps that you can take to help you get past that:
info316330
I followed the instructions on the link above 2 times, but the problem is that in the path:
the file does not exist! It not created by installation process...
Dreamweaver
OK
The active configuration paths that are used by DW are stored on a per user basis. So in the error you are getting this is not where the actual file is stored, it is instead stored in the users configuration folder.
Did you delete or rename your users configuration folder with DW closed, then remove the extensions and re-install them? You will need to do this part to get past this error. Please post back if you have any additional questions or run into any problems with this.
