Menu instead of list
Thread begun 5/21/2009 5:50 am by richard347309 | Last modified 5/21/2009 10:09 am by Ray Borduin | 3794 views | 3 replies |
richard347309
I was wondering if it was possible to use Dynamic Dropdowns with Menu's instead of List. I have been trying to find a solution to this and doesn't seem to be working with Menu's. Just wondering if it's possible
What do you mean when you say "menu"... if you mean multiselect lists, I think it should work.
richard347309
When you first put in a new List/Menu you have the option to either have type Menu or type List. The example only shows you how to do list but I figured out that its the exact same way but you can't do multiselect Menu, you can do multiselect lists though. Thanks Ray
I just wanted to make sure that is what you are talking about. In HTML they are both form SELECT elements. Dreamweaver differentiates them by calling them lists and menus, but lists can also be <ul> and <li> tags, and menus is often the term to refer to navigation.
