Security Assist
Thread begun 3/17/2010 5:51 pm by Gizza372666 | Last modified 3/19/2010 11:52 am by Eric Mittman | 1964 views | 3 replies |
Gizza372666
Security Assist
can you use Security Assist to overcome the following problem?
I have created a page that a user has to logon and by using URL parameter will navigate through pages and check/add/update/delete different fields that belong to this specific user (by using the UserID field)
UpdateBanner.php?UserID=<?php echo $row_WAATKusers['UserID'];?>
The problem I have is that if a user has ID 2 (UpdateBanner.php?UserID=2)
if this user type (UpdateBanner.php?UserID=3) on the address bar he/she will have access on the next record so he/she will be able to make changes on someone else’s record.
Can you please let me know if it is possible to overcome this issue? And how?
thanks
Security Assist could help you to overcome this issue. With the Security Assist Authenticate User server behavior used to login a user you will have the ability to store any details from that users record in a session variable. By default it will try to create a session variable for the userID. So when you go from page to page you should not pass the userID over the URL but you should use this userID session variable instead.
So if you are storing the userID in a session variable called userID you would reference the user id like this instead of the get:
$_SESSION['userID']
Gizza372666
Job done!
I just managed to understand it.
Thank you very much.
Glad to hear that. Let us know if you have any further questions.
