Image name changed.
Thread begun 3/16/2010 2:31 pm by mja394004 | Last modified 3/17/2010 12:11 pm by Jimmy Wu | 1842 views | 3 replies |
mja394004
Image name changed.
This is a new site.
If I upload an image, the name of the image is changed when stored in the images/upload folder, but it is not changed in the mySQL file.
For example: If I upload an image named ABCDEF1234.jpg, the upload appears to work.
There fore when html trys to render the image, it cannot be found.
The way uploading works is that the image will be uploaded to the temp directory of the server and then copied over to the specified upload directory. The reason the name of the file is incorrect is that it gets uploaded with a temporary name and then the name is modified to the correct name when its copied. So some permissions are not set correctly on either the temporary directory or the upload folder. Make sure the permissions on those are set to 777.
mja394004
image upload failure
Thank you Jimmy.
In fact it was a permission issue.
Works fine now.
