dynamic dropdown and redirecting to new page
Thread begun 3/05/2010 9:47 am by nvdhassani382788 | Last modified 3/08/2010 11:44 am by Eric Mittman | 7555 views | 5 replies |
nvdhassani382788
Hello,
I am trying to use my drop down menu so I can link to a new webpage.
I have created two tables in mysql, And I want the customer to be able to click a Button once the child dropdown menu is selected and go to the next page.
CREATE TABLE `categories` (
`cat_id` mediumint(8) unsigned NOT NULL auto_increment,
`cat_name` varchar(28) default NULL,
PRIMARY KEY (`cat_id`)
) ENGINE=MyISAM;
CREATE TABLE `companies` (
`comp_id` int(10) unsigned NOT NULL auto_increment,
`comp_name` varchar(48) NOT NULL,
`comp_cat_id` mediumint(8) unsigned NOT NULL,
PRIMARY KEY (`comp_id`)
) ENGINE=MyISAM;
INSERT INTO `categories` (`cat_id`, `cat_name`)
VALUES (1, 'Air Conditioning & Heating');
VALUES (2, 'Alarm/Security');
VALUES (3, 'Appliances');
VALUES (4, 'Carpet & Upholstery Cleaning');
VALUES (5, 'Day Care');
VALUES (6, 'Electrical');
VALUES (7, 'Energy Savers');
VALUES (8, 'Fence & Deck Services');
VALUES (9, 'Flooring');
VALUES (10, 'Foundation Repair');
VALUES (11, 'Garden & Landscaping');
VALUES (12, 'Home Entertainment');
VALUES (13, 'Home Furniture');
INSERT INTO `companies` (`comp_id`, `comp_name`, `comp_cat_id`)
VALUES (1, '1st Class Air Service', 1);
VALUES (2, 'Chapman Air', 1);
VALUES (3, 'Dallas Plumbing Company', 1);
And my dynamic dropdown script is
<div id="steps">
<div class="stepone">
<h4> Step One: </h4>
<p>Choose a Category</p>
<form id="form1" name="form1" method="post" action="">
<select name="Parent" id="Parent" onchange="WA_FilterAndPopulateSubList(Child_WAJA,MM_findObj('Parent'),MM_findObj('Child'),0,0,false,': ')">
do {
<option value="<?php echo $row_Parent['cat_id']?>"><?php echo $row_Parent['cat_name']?></option>
} while ($row_Parent = mysql_fetch_assoc($Parent));
$rows = mysql_num_rows($Parent);
if($rows > 0) {
mysql_data_seek($Parent, 0);
$row_Parent = mysql_fetch_assoc($Parent);
</select>
</form>
<p>&nbsp;</p>
</div>
<h3> Step Two:</h3>
<p> Choose a Company (Optional) </p>
<form id="form2" name="form2" method="post" action="">
<select name="Child" id="Child">
</select>
</form>
<p>&nbsp;</p>
</div>
<h2> Step Three:</h2>
<img class="go" src="images/global images/gobutton.png" alt="Go" />
</div>
</div>
I was wondering if I need to create another column in my table that holds the URL for all those companies and how do I make the GO button recall that column in the table and open the new page?
asnw0764437428
redirect to new page
In your form tag you haven't entered the results page name eg
<form id="form1" name="form1" method="post" action="name_of_your_results_page.php">
If you want the the drop list items you selected to be remembered I would also put this in the body tag:
onLoad="WA_FilterAndPopulateSubList(Child_WAJA,M M_findObj('Parent'),MM_findObj('Child'),0,0,false, ': ')"
nvdhassani382788
update
you can look at the page here to get a better idea.
mysavings.php
use username: tester
password: tester
nvdhassani382788
Sql
So I don't have to put the URLs in mySQL database?
What I basically want is you select a category and then select a company and click Go to go to that companies page.
I also want to be able to use the category only to go to a page with an overview of all the companies.
In my drop down menu I'm gonna add view all.
For instance, you select Pool services and then in the child menu its going to give you the option of viewing them all or just select one company and click the submit button.
Thanks for all the help again
nvdhassani382788
how do i open new page from dynamic dropdown
Can anyone please help me with this:
I have set up this script
<form id="form1" name="form1" method="post" action="<?php echo $row_Child['comp_url']; ?>">
<select size=1 name="Parent" id="Parent" onchange="WA_FilterAndPopulateSubList(Child_WAJA,MM_findObj('Parent'),MM_findObj('Child'),0,0,false,': ')">
<option value="">Please Select Below</option>
do {
if($rows > 0) {
</select>
</form>
<p>&nbsp;</p>
</div>
<h3> Step Two:</h3>
<p> Choose a Company <strong><em>(Optional) </em></strong></p>
<select size=1 name="Child" id="Child">
<option>Please Select a Company</option>
</select>
<input type="image" src="images/global images/gobutton.png" name="go" id="go" value="Submit" />
</form>
^^Doesn't quite work. It gives me this error
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/content/h/o/m/homepagesdfw/html/mysavings.php on line 395
Line 395 is mysql_free_result($Child);
Is there any webassist support on this?
I was not able to view your sample page with the username and password provided. It seems that you have a dynamic dropdowns implementation in place and would like for the child menu to hold URL values from your table correct? If so you are mostly there, to get the page to go to the URL of the selected value in the child list you will need to use some javascript. In your js code you will have the onclick of the go button do a window.open call. In this call you will use the value of the selected index's option of this child list. So the go button's onclick event might be set like this:
onclick="window.open(getElementById('<the id of your child select list>').options[getElementById('<the id of your child select list>').selectedIndex].value)"
