Help! Major Powerstore Parse error
Thread began 3/05/2010 7:48 am by Neilious | Last modified 3/05/2010 10:21 am by Jason Byrnes | 936 views | 2 replies |
Neilious
Help this appears at the top of the homepage, my client was adding products to the site via the admin area at the time but that was all that was going on.
Parse error: syntax error, unexpected T_STRING in /web2/user23268/website/WA_Globals/WA_Globals.php(58) : eval()'d code on line 1
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /web2/user23268/website/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /web2/user23268/website/WA_eCart/WA_eCart_Definition_PHP.php on line 480
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /web2/user23268/website/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /web2/user23268/website/WA_eCart/WA_eCart_Definition_PHP.php on line 480
I've replaced the WA_Globals.php, WA_eCart_Definition_PHP.php with original backup files but it's made no difference.
Please help, I'm completly stuck
Neilious
Big relief - solved
Solved it by searching the forum here's Jason's solution
  This can happen if you use an apostrophe i nthe store name.
in the WA_Globals.php file, change line 58:
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
to:
eval("\$WAGLOBAL_".$value[$x][4]."='".addslashes(replaceTokens($value[$x][1],$tabs))."';");
This is also posted as a known issue in the Power Store 3 download page.
