CSS Sculptor and Expression web 2 editing
Thread begun 5/15/2009 11:36 am by ed363534 | Last modified 5/18/2009 9:27 am by Justin Nemeth | 4697 views | 4 replies |
ed363534
Hi
I suppose I have got this wrong! I have created a new web site (well the first page) using Expression web 2 and CSS Sculptor. I have now tried to edit it. I used the Insert -Web Assist -CSS Sculptor -Layout Manager option. I added a background image to the Header and followed the instructions to finish only to find that my web layout has not altered at all!
I used Preview and saw that the web layout had changed. what do I need to do to save the altered layout as my web?
Geoff
CSS Sculptor is not re-entrant. If you want to change the design you need to create a new page with the new design after updating it.
ed363534
Thanks Ray
But I think I am still missing something. Following what I have done what have I created? I used Insert as there was no edit option. But no page has been created. If I follow the same path my previous alterations to the selected layout are saved. But no new page is created. After using Edit I pressed Finish and Done.
I have managed to make a modified page. I selected New CSS Sculptor Page. I next chose under Presets, Choose a preset layout,. then I selected the layout I had modifiied and sure enough I had created the new page according to my modifications. :)
Geoff
That does sound like it could be a bug. Please submit a support incident at the webassist web site, I'm not too familiar with expression web or the potential issues.
Justin Nemeth
Geoff, double check the output tab is setup correctly to generate a page for you. It's possible there is a setting enabled that is only saving your layout, but not actually creating a page for you. It should be as simple as unchecking that box on the output tab.
