Using SHA1 with password
Thread begun 5/15/2009 4:24 am by phil.evans372967 | Last modified 5/15/2009 12:00 pm by Ray Borduin | 6836 views | 11 replies |
phil.evans372967
Hi all
Has anyone adapted the sign up, login and forgotten password pages to work with SHA1? If so could you give me some help in getting it all to work together?
With thanks
Phil
Where are you having difficulty? What is the problem you are having? What have you tried?
phil.evans372967
Hi Ray
I've set up my users database table and run the securityassist wizard to create the register, login and send password pages, and that all works a treat, but I want change my code to be able to hash the passwords at register, login and email password.
Phil
In the bindings tab there is a formatting option. You can add SHA1 encryption to any value from there.
You would just update the bindings and add encryption on the four pages you specified.
phil.evans372967
Hi Ray,
I can't see any option under the bindings tab. Should it be a sub menu of securityassist?
Phil
When you click a lighning bolt from an insert, update, or other server behavior... you should see a format dropdown list below the tree where you select the binding.
phil.evans372967
I'm trying to do my login page first
prop_users_LogIn.php
which has a form called WAATKLogInForm with username and password fields
but I can't see anything in the bindings panel that will allow me to change the formatting to SHA1. I'm using CS3
Phil
You should be editing the server behavior and clicking the lightning bolt where you bind the password value.
phil.evans372967
Gotcha! Thanks Ray. Easy when you know how.
Thanks again
Cheers
Phil
phil.evans372967
Me again, sorry to pester you with this. How can I achieve the reverse so that when the retreive password email is sent it's converted back from SHA1?
Phil
