Security Assist and CS4
Thread began 5/14/2009 12:30 pm by brett171768 | Last modified 5/14/2009 2:21 pm by brett171768 | 3404 views | 6 replies |
brett171768
I've replicated this 3 times now....
But each time I install Security Assist in DW CS4, it deletes my formatting options in the Bindings Panel. For example, if I want to format the date for a date field, when I click to format the "Date/Time", I have no options available.
I reinstall DW CS4 and the formatting is back. I install Security Assist, they're gone.
Anybody seeing this?
Brett
The issue is that Extension Manager has a bug in it where the formats.xml file for each server model has an empty title attribute for each format entry. Remove the title=””, save the file and restart DW, and things should be good to go.
To find the file go to:
%appdata% (or your user application library folder)
then browse to the DW version you are using and continue to:
/Shared/ServerFormats/PHP_MySQL/Formats.xml
There will be a formats.xml file for each server model that will need to be updated (assuming that SecurityAssist adds the format to every server model.
brett171768
The file will be located:
Ray,
I'm using ASP VBscript and my folder structure doesn't match what you outline. I have:
adobe/adobe dreamweaver cs4/configuration/serverformats/php_mysql
adobe/adobe dreamweaver cs4/configuration/serverformats/asp_vbs
etc...
Either way, I can't find any reference to an empty title tag in any of the files withint the asp_vbs folder.
Brett
you should find a file called Formats.xml in the asp_vbs folder.
Open up that file in notepad and you will see the error.
brett171768
I'm sorry, I don't see an empty title="" tag.
I do see a title"
I tried removing that and it doesn't fix the problem.
Here is my current file:
formats.xml
Brett
This is the original formats.xml file.... I think you opened the version in your program files.
open explorer and type: %appdata%
Then browse to the file in that location. I think you are probably just looking at the wrong file.
brett171768
I found the correct file and made the changes.
Brett
