Buttons Hidden
Thread began 2/24/2010 10:37 pm by jed193733 | Last modified 3/02/2010 3:33 pm by Eric Mittman | 1542 views | 6 replies |
jed193733
Buttons Hidden
The screen image attached displays that I can't access the buttons to process my Data Assist request... NO IDEA WHERE to turn .... thanks in advance
try increasing your screen resolution to 1024 x 768 or possibly higher.
jed193733
Thanks...but..
I'm running 1280X800 WXGA already...
I did a reinstall already...
the reating tabel behavior is 840 pixels tall, you need to select a screen resolution that offers more than 840 pixels for height.
You should also check on your display DPI setting, a normal DPI is 96. Usually when I see scroll bars in the interface this is the issue. There might be a problem with the minimum resolution still but adjusting this setting would be worth a try.
To adjust this in vista right click on the desktop and click on personalize, there should be a Font Site (DPI) link on the left. Check here to see if you have the standard or a larger value.
jed193733
Thanks...
Good call Eric - Vista - set to custom 106....thanks again
Glad to hear that, I have encountered that issue myself.
