Pages from same template shifting horizontally
Thread begun 2/14/2010 9:30 pm by WilliFixit | Last modified 2/16/2010 3:15 pm by neilo | 4769 views | 10 replies |
WilliFixit
I have some pages from the same template that are shifting 9 pixels horizontally. Thought someone would be able to tell me why.
See:
http://willadamsphoto.com/aboutme/photohistory.php
http://willadamsphoto.com/aboutme/myprocess.php
Thanks for any help on this! :) :)
neilo
It jumps a little if you go from a short page to a long page when the scroll bar appears. This is the standard behaviour for Firefox/Mozilla.
In IE it stays in the same position.
WilliFixit
Thanks, neilo,
But on my machine it shifts with either IE or Firefox/Mozilla.
Too bad...it's a bit distracting.
neilo
Hi Will,
I'm not seeing that in I.E, but you're not alone in being annoyed. There is a similar post here and John Langer has posted a link that might (or might not) be helpful.
neilo
Justin Nemeth
Thanks for the link neilo. Will, if you follow the example that neilo posted that will essentially force the scrollbar to always show and stop the page shifting.
-justin
WilliFixit
Thanks, Justin,
In the link, he says:
You can add some simple styles to your site's style sheet to force a vertical scrollbar to always show and thus get rid of the page shift. The most obvious solution is to add an overflow: scroll rule to the html element. However, this rule adds a horizontal scrollbar as well, which web users definitely don't like. Here's an easy and valid way to force only the vertical scrollbar to appear, no matter what size the viewport is:
html { min-height: 100%; margin-bottom: 1px; }
If I am using the mystyles.css to modify the default SiteAssist Pro CSS, where do I put this HTML code? Do I have to put it on all pages????
Justin Nemeth
The mystyles.css is already included on each page, so adding it to that file should be all that is needed.
-justin
WilliFixit
I did add it, to the top of my mystyles.css just as:
But no changes happen to the pages. Is there something else I should do, or change?
neilo
Hiya Will,
Another way to force a vertical scroll-bar in Firefox is to use overflow-y: scroll; in the css rule for your
body element:
body {
background-color: #252525;
color: #B9B9B9;
/* The rest of the body styles here */
overflow-y: scroll;
However, while this looks and works fine in Firefox and IE8, if you look at the same page in IE7 or older IE browsers, you will see that you have a new problem, in that IE will insert a second scroll-bar - usually the same length as the run of the page content.
So to get round this you would have to duplicate your stylesheet - but without the 'overflow-y' style - and create a conditional style comment:
<!--[if lte IE 7]>
<style type="text/css" media="all">
@import url("path_to_your/IE7.css");
</style>
<![endif]-->
which would need to be included in the head of each page.
You can see the effects of this method when the conditional css has not been aplied (if you have <= IE7) here but in Firefox or IE8 you will see that it has added the scroll bar track even where the page length doesn't require it.
WilliFixit
Thanks again. I will try a few options and see what works/looks best. I may just (as lots seem to resign themselves to do) live with the shift.
