Search problem
Thread begun 2/11/2010 9:32 am by hbibizadeh396670 | Last modified 2/11/2010 5:12 pm by Jimmy Wu | 2319 views | 3 replies |
hbibizadeh396670
Search problem
I followed instructions on how to create the search pages and finished them successfully.
However my problem is that when i search is get this error
Fatal error: Call to undefined function curl_init() in C:\wamp\www\ashperfectimage\Yahoo\BOSS_include.php on line 4
Please Help
Curl support is not enabled on your server. You should contact your server provider or server administrator to get this installed/enabled.
26167-fatal-error-call-undefined-function-curl_init.html
robert222776
You might try this. I had a similar problem with eCart, and am using xampp. This is what Jason said to do, and it worked.
In your case, edit the wamp php.ini file to enable the cURL extesnion.
in the php.ini file, find the following line:
;extension=php_curl.dll
and change it to:
then restart the wamp server.
Hope this helps,
Robert
Thanks for helping with how you got it working in xampp.
