need to add usps shipping option (along with UPS)
Thread begun 2/10/2010 10:04 am by tim299030 | Last modified 4/06/2010 12:53 pm by Eric Mittman | 7235 views | 14 replies |
tim299030
I have a store that currently uses UPS as it's shipping option but my customer wants to include USPS as an additional customer selectable option. Is there a recipe or some documentation for this?
If not, what steps are necessary for making it so the customer can choose either UPS or USPS?
Tim
We don't have any documentation on getting two different providers working together. You could start by setting up the additional server behavior then modifying the triggers to work with the form element the user selects to choose one over the other.
This selection should occur on the checkout page, you can just add a radio group or a select list for the user to choose from.
Next on your confirm page you would apply the new USPS shipping server behavior and configure it accordingly. Once you have both of them on the confirm page you can them update the triggers to look at the posted value for the shipping selection that comes from the checkout page. If it is one value you would use UPS, and if it is the other value you would use USPS.
Please post back with questions about any part of this that you are not familiar with and I will gladly expand and give you some more specifics.
tim299030
I've added the menu on the checkout page and added the server behavior on the confirm page. I'm not sure how to configure the trigger.
How do I pass the value "UPS" or "USPS" to the confirm page? My menu uses the select name and id of "shipping_type" and it shows up in the "ecart_checkout_form" on the checkout page in the bindings panel, but "shipping_type" doesn't show up as an option in the confirm pages binding panel.
You can try adding the form data binding and select the checkout page to see if that updates the bindings and allows the select list to be available to you. If that does not work you can set the trigger manually by selecting any posted form element and changing the name listed in the trigger like this:
<?php echo isset($_POST['your form element'])?$_POST['your form element']:"" ?>
This is just to get at the value, the actual trigger should look like this when you see it in the code:
if((isset($_POST['your form element'])?$_POST['your form element']:"") == 'UPS'){
the UPS shipping quote server behavior here
} else {
the USPS shipping server behavior here
If you post back with the code for the select list that is in your checkout form I can give you a better example of this.
tim299030
I think I follow you. Here's what I did:
First, here's my form element from the checkout page:
****************FORM ELEMENT FROM CHECKOUT PAGE*********************
<table border="0" cellspacing="0" cellpadding="0" class="eC_SameAsWrapper" >
<tr>
<td style="padding-right: 10px;">Shipping type: </td>
<td style="vertical-align: top;"><select name="shipping_type" id="shipping_type" >
<option value="UPS">UPS</option>
<option value="USPS">USPS</option>
</select>&nbsp;<span style="color:#A14A35; font-size:18px;">*</span></td>
</tr>
</table>
****************END FORM ELEMENT FROM CHECKOUT PAGE*********************
Then, on the confirm page I put the trigger in manually:
<?php echo((isset($_POST["shipping_type"]))?$_POST["shipping_type"]:"") ?>
Here's what the result is after I do the above:
if ((((isset($_POST["shipping_type"]))?$_POST["shipping_type"]:"") != "")) {
//WA eCart (Copyright 2007, WebAssist)
//WA eCart UPS Shipping - UPS
$Shipping_SuccessURL = "";
$Shipping_FailureURL = "shipping_failure.php";
$Shipping_Packaging = 0;
$Shipping_PackageArray = array();
$Shipping_PackageIndex = 0;
$Shipping_Counter = 0;
$Shipping_Parameters = array();
$Shipping_Parameters["UserID"] = "MY_CUSTOMERS_USER_ID";
$Shipping_Parameters["Password"] = "MY_CUSTOMERS_PW";
$Shipping_Parameters["AccessKey"] = "MY_CUSTOMERS_ACCESS_KEY";
$Shipping_Parameters["CarrierCode"] = "03";
$Shipping_Parameters["PickupType"] = "03";
$Shipping_Parameters["CustomerClass"] = "none";
$Shipping_Parameters["ShipperNumber"] = "MY_CUSTOMERS_SHIPPER_NO";
$Shipping_Parameters["ShipperCity"] = "Findlay";
$Shipping_Parameters["ShipperState"] = "OH";
$Shipping_Parameters["ShipperZip"] = "45840";
$Shipping_Parameters["ShipperCountry"] = "US";
$Shipping_Parameters["ShiptoCity"] = "".((isset($_POST["shipping_city"]))?$_POST["shipping_city"]:"") ."";
$Shipping_Parameters["ShiptoState"] = "".((isset($_POST["shipping_state_province"]))?$_POST["shipping_state_province"]:"") ."";
$Shipping_Parameters["ShiptoZip"] = "".((isset($_POST["shipping_postcode"]))?$_POST["shipping_postcode"]:"") ."";
$Shipping_Parameters["ShiptoCountry"] = "".((isset($_POST["shipping_country"]))?$_POST["shipping_country"]:"") ."";
while (($Shipping_Packaging == 1 && !$RoyaleCart->EOF()) || ($Shipping_Packaging == 0 && $Shipping_Counter == 0)) {
if (WA_eCart_UPS_IsTrueValue("true")) {
$Shipping_PackageArray[] = array();
$Shipping_PackageIndex = sizeof($Shipping_PackageArray)-1;
$Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$RoyaleCart->DisplayInfo("Quantity"):1);
$Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "1";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$RoyaleCart->DisplayInfo("TotalWeight") ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "02";
$Shipping_PackageArray[$Shipping_PackageIndex]["SizeUnits"] = "IN";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageLength"] = "17";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWidth"] = "11";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageHeight"] = "8";
//Special Services
$Shipping_Counter++;
if ($Shipping_Packaging == 1) $RoyaleCart->MoveNext();
if ($Shipping_Packaging == 1) $RoyaleCart->MoveFirst();
$Shipping_Result = WA_eCart_UPS_GetRateQuote($RoyaleCart, $Shipping_Parameters, $Shipping_PackageArray);
if ($Shipping_Result && $Shipping_SuccessURL != "")
$RoyaleCart->redirStr = $Shipping_SuccessURL;
else if (!$Shipping_Result && $Shipping_FailureURL != "") {
Header("Location: " . $Shipping_FailureURL); exit;
else if (!isset($_SESSION["RoyaleCart_UPS_Success"])) {
WA_eCart_UPS_SetSessionDefaults($RoyaleCart);
//WA eCart USPS Shipping - USPS
$Shipping_FailureURL = "checkout_failure.php";
$Shipping_Parameters["USPSServer"] = "http://production.shippingapis.com/shippingapi.dll";
$Shipping_Parameters["CarrierCode"] = "PRIORITY";
$Shipping_Parameters["DefaultIntl"] = "Global Express Guaranteed Non-Document Service";
$Shipping_Parameters["ShiptoZip"] = "".$_SESSION['eCartCheckoutForm_shipping_postcode'] ."";
$Shipping_Parameters["ShiptoCountry"] = "".$_SESSION['eCartCheckoutForm_shipping_country'] ."";
if (WA_eCart_USPS_IsTrueValue("true")) {
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "lb";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($RoyaleCart->TotalColumn('TotalWeight'), true, 1) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "YOURPACKAGING";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageSize"] = "REGULAR";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageMachinable"] = "none";
$Shipping_PackageArray[$Shipping_PackageIndex]["IPackageType"] = "Package";
//Special Services
$Shipping_Result = WA_eCart_USPS_GetRateQuote($RoyaleCart, $Shipping_Parameters, $Shipping_PackageArray);
else if (!isset($_SESSION["RoyaleCart_USPS_Success"])) {
WA_eCart_USPS_SetSessionDefaults($RoyaleCart);
Am I in the ball park? Do you need to see the actual files?
Thanks for your help.
Tim
You are very close, you just need to update these two triggers to check for the specific value of the posted element, like this:
if ((((isset($_POST["shipping_type"]))?$_POST["shipping_type"]:"") == "UPS")) {
For the second server behavior you would update to be like this:
if ((((isset($_POST["shipping_type"]))?$_POST["shipping_type"]:"") != "UPS")) {
This way it will check if the user selected UPS, and if not the USPS shipping quote will be used.
tim299030
Eric -- I thought I followed your instructions well but it appears I'm missing something. I'm getting the following error:
Parse error: syntax error, unexpected T_CONCAT_EQUAL in /home/royaleco/public_html/WA_eCart/WA_eCart_USPS_PHP.php on line 49
I'll attach the files I think you need. If you need additional or different ones please let me know.
Did you select USPS as the shipping type? In the file I have with this name the line of code referenced is just checking on the package weight. Here is the line of code that I have on the line referenced:
if ($USPS_LbWeight > 0 || $USPS_OzWeight > 13.0)  {//weight limit for first class
Is this the same line of code that you have on line 49? If so then ther is probably a bad value that is being used within this server behavior. Are you using First Class mail as the type of mailing for USPS? Please post back with this info and if we need to look into this further I can open a ticket so we can exchange the files in private.
tim299030
Eric,
Line 49 in my document is:
$USPS_XML ..= "<Service>" . $USPS_Parameters["CarrierCode"] . "</Service>";
I have it set in the server behavior for Priority NOT First Class.
Tim
What is the version of eCart that you are working with? This looks like an old issue that has been updated in the newer releases of eCart. I'm including a new updated copy of the USPS file for you. Make a backup of yours and replace it with this newer file and test it out again.
The problem with the line of code is the dot dot where it is assigning the value to this variable.
This
$USPS_XML ..=
should be this
$USPS_XML .=
