PayPal "Error Detected" - shopping cart is empty
Thread began 3/27/2011 10:45 pm by SaladoGuy | Last modified 3/30/2011 3:18 pm by Jason Byrnes | 2915 views | 9 replies |
SaladoGuyBeta Tester
I have made several carts using eCart and PayPal as my main checkout gateway. The site is live (softdipes.com) and I am getting the following error when I try to checkout.
Error Detected
Your shopping cart is empty
The order is being stored in the database but PayPal seems to not be getting any data. Any ideas?
Thanks
P.S. I included a zip of most of my website. I would upload the whole website, but can't due to the file size limit.
Hope I included in the zip, everything you need to see help me with my problem.
softdiapes.zip
Jason Byrnes
When I view source of the confirm page, the item name being passed to paypal is empty:
<input type="hidden" name="item_name_1" id="item_name_1" value="" />
The item name is a required value.
it would seam that the add to cart button is not populating the Name column of the cart object.
How would be the best way to fix this issue?
Thanks,
Mark
Jason Byrnes
you need to make sure the add to cart buttons are populating the name column of the cart object.
Is there a article on how I can find out how to fix this problem?
I'm not exactly sure to do what you said.
Thanks for your help.
Jason Byrnes
the problem is in the add to cart button server behaviors.
on any page that you have added the add to vcart button server behaviors, you need to edit the Add to cart button server behavior to make sure that a product name is being added to Name column in the cart.
Originally Said By: Jason Byrnes
I believe this fixed it, I modified the binding the in Server Behaviors. It now posts through to PayPal correctly.
However now I have a different problem, when I select a size option on the product page, it's supposed to increase the price (Medium, add $2, Large, add $4) and these prices are supposed to be pulled from the database. This no longer works, the price is not increased in the cart, even though the fact that the size has changed is showing correctly on the viewcart page. I can't figure this one out I've tried changing the binding to several different things and none are working. Could you show me how to set that binding right?
If I was just trying to echo the option, I would use this and it would work:
<?php echo $row_rsSize['OptionPriceIncrement']?>
I tried setting the binding to just that and it did not cause the actual item price to increase in the cart.
// WA eCart AddToCart
if (isset($_POST["softdipes_cart_1_ATC"]) || isset($_POST["softdipes_cart_1_ATC_x"])) {
$ATC_itemID = $_POST["softdipes_cart_1_ID_Add"];
$ATC_AddIfIn = 2;
$ATC_RedirectAfter = "viewcart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsProduct) && $totalRows_rsProduct > 0) {
$row_rsProduct = WAEC_findRecordMySQL($rsProduct, "ProductID", $ATC_itemID);
if ($row_rsProduct) {
$ATC_itemName = "".$row_rsProduct['ProductName'] ."";// column binding
$ATC_itemDescription = "".$row_rsProduct['ProductDesc'] ."";// column binding
$ATC_itemThumbnail = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["softdipes_cart_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rsProduct['ProductPrice'] ."");// column binding
$ATC_itemcolor = "".$_POST["softdipes_cart_1_color_Add"] ."";// column binding
$ATC_itemsize = "".$_POST["softdipes_cart_1_size_Add"] ."";// column binding
$ATC_itemsizePriceInc = "".$_POST["softdipes_cart_1_sizePriceInc_Add"] ."";// column binding
mysql_data_seek($rsProduct, 0);
$row_rsProduct = mysql_fetch_assoc($rsProduct);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$softdipes_cart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemcolor, $ATC_itemsize, $ATC_itemsizePriceInc);
if ($ATC_RedirectAfter != "" && $softdipes_cart->redirStr == "") {
$softdipes_cart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
Jason Byrnes
see the "Product Options with eCart" tutorial on the eCart page for details on Options that effect price.
We have done that and I'm not able to see what's wrong. At this point I would really like to find the specific problem and fix it instead of gutting the site and starting over again. I have a feeling that will cause even more problems than what I have now.
I've attached the most recent version of the site, is there any way you could please look at it and see what's wrong?
The live site is product.php and you can see what I'm talking about (if you need to) there by adding a product to the cart with Medium or Large option. You'll see that the price does not increase over the base price. Everything else seems to be working fine.
Thanks!
softdipes_for_WA.zip
Jason Byrnes
the way that options effect price is to use a priceLookup recordset.
your option select list needs to pass the option ID into a recordset to return the option name and the option price increment.
when you have options that effect price, you do not set the Update ble from a select option for the option column.
you need to create the option select list manually. you will need a recordset to populate the option select list.
the label will use the option name.
the value will use the option ID.
then create a second recordset to lookup the price of the selected option.
In the add to cart button, you bind the option name and the price increment columns of the cart to name and price increment columns of the price lookup recordset.
This is not the way you have configured the add to cart buttons.
the ecart options tutorial is broken into 2 parts. the first part uses options that do not effect price.
the second part uses options that do effect price. Look through that second part of the tutorial again for full details.
I'm not suggesting that you gut your site. Only that you are not following the relevant parts of the tutorial to accomplish your goal.
We were unable to get the attached file
