Create a Blog using PowerCMS Builder
Thread began 2/26/2012 12:06 am by Daryl | Last modified 9/22/2016 6:53 am by anonymous | 4231 views | 6 replies |
DarylBeta Tester
Im trying to build a blog or news type area using the PowerCMSBuilder extension but am having real issues sorting out the navigation menus to make this work properly.
I really like the way that clients can use the CMS to add articles (page from template) although I really wish that users couldnt alter the 'template' and could only add, but never mind about that at the moment.
I have had help to create a list of Months and Years with a record count in brackets after as an archive menu - http://www.webassist.com/forums/showthread.php?t=24940 and I have managed to create a list of the last x no of recent News posts, the problem that I am having now is filtering the recordset by month and year.
I have tried various ways of filtering the recordset daetime column using a url variable but just cant get it to work.
Has anyone else made a blog/news section like this?
Does anyone have an example of the code that they used that they could share with me?
so from the linked thread, the base recordset you are using is:
SELECT Date_format(pcms2_contents.ContentDate, '%M, %Y') as contDate,
COUNT(*) AS cc FROM pcms2_contents
WHERE pcms2_contents.ContentPageName='News' AND pcms2_contents.ContentPageSetParentID=12
GROUP BY YEAR(pcms2_contents.ContentDate),
MONTH(pcms2_contents.ContentDate)
ORDER BY pcms2_contents.ContentDate DESC
to filter by a month and year url variable, you would need to pass the 2 digit month number in the querystring, and the 4 digit year in the quertystring for example:
news.php?month=02&year=2012
then in the recordset, use DATE_FORMAT to convert the date to year and month pieces: add to the where clause:
WHERE pcms2_contents.ContentPageName='News' AND pcms2_contents.ContentPageSetParentID=12 AND DATE_FORMAT(pcms2_contents.ContentDate, %m) = paramMonth AND DATE_FORMAT(pcms2_contents.ContentDate, %Y) = paramYear
then in the variables section, create 2 new variables as:
type: date
default value: -1
runtime value: $_GET['month']
type: date
default value: -1
runtime value: $_GET['year']
RonnieJaysmith
The majority of people are still only discussing Wordpress, Joomla and Drupal as the three best Open source Content Management Systems. These systems will be reviewed through first hand experience. But, we will add to the equation, a Commercial Open Source CMS system called WebriQ and analyze the major differences between the three open source system and then group those open source system and compare them with a Commercial Open source system.
Ronnie
Ronnie,
This is a support forum for the WebAssist Power CMS Solution, it is not a forum for you to debate the merits of other systems on the market.
If you have a question pertaining to Power CMS, feel free to post your question. otherwise, your post is irrelevant to this forum. Please refrain from adding noise.
this is the second time i have seen you post, both posts have been basically the same, this is not the place for your posts.
Cheers
Jason
nupivu56440538
I didn't know I can use it for blog. Is it user-friendly enough for a newbie blogger? I think I will need some help with installation and settings...
DarylBeta Tester
Its fairly easy to use to create a blog although you will need a small amount of hand coding to create the various dynamic menus.
You would also need to use the social media toolkit to create a comments system or hand code one from scratch.
anonymous
This post has been deleted.
