Inserting images from server
Thread began 2/09/2010 12:45 am by ffiguerola395137 | Last modified 2/24/2010 1:08 pm by Eric Mittman | 1214 views | 3 replies |
ffiguerola395137
I've a trouble with the insertion of images. When I try to insert them on my page (into a text field in the FCKEDITOR) I can see the image in the directory of the server to choose it but when I click to insert appears only the name of the image, not the image.
This doesn't happens in my test environment (local site).
Could anyone help me.
Thanks in advance.
This sounds like it may be a pathing issue to the image. The best way to determine if it is a path issue is to use the source button to view the source for the image. In the <img tag you will see the src attribute. This is the path that is being used for the image, you should be able to take a look at this path and try to match it up to the correct path to the image on your server. Let us know what you discover.
If you have any trouble with this we can take a look for you to see if we can spot the issue, let us know.
ffiguerola395137
Thank you
I don't know what happened, but I've re-annexed the editor to the field I wanted to edit and then It works.
Thanks for your support.
That is good news, let us know if you have any further questions or if you encounter any problems.
