Flat Rate Discount that can only be used one time
Is it possible to build a Promo Code or discount that offers a flat rate discount that can only be used one time?
once per user or once period?
either way, you would need to store the promo code in in the orders table on checkout, then create a recordset to lookup the promo code in the database. Then set the trigger for the PromoCode session variable to occur only if the recordset is empty.
