Insert Record Problem
Thread began 2/04/2010 2:50 pm by mrobben375515 | Last modified 2/05/2010 9:46 am by Jason Byrnes | 953 views | 1 replies |
mrobben375515
We are uploading a file with Digital File Pro and inserting a record into the database at the same time. When I hit submit, the form seems to process, but they returns with nothing submitted. The text fields are still populated with the data I entered, but the file field is blank. The URL returns a \index.php?invalid=true. There are not any other error messages. How do I diagnosis the problem? I already deleted the WA Insert and WA File upload server behaviors and re-set them up.
It sounds like you have server validation on the page that is causing the problem.
look for the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"confirm");
and change it to:
    die($WAFV_Errors)
this will write a comma separated list of the validation that have failed to the screen. Post back the comma separated list and a copy of your page so I can examine the code.
