Data Assist Customizing Results Page
Thread began 2/03/2010 2:38 pm by elewis93815 | Last modified 2/04/2010 12:17 pm by Jason Byrnes | 755 views | 1 replies |
elewis93815
Is there a way to customize your results page in a specific format?
We are attempting a few different elements.
1. we would like to have our results page to populate looking like the following:
This is how I would like the search to come back (the format):
results_TEMPLATE3.php
2. I would like to have more than one record retrived (if there is more than one record).
3. Will I need buttons (links) to move through the search?
e.g. If I search an "exhibitor" name and that persons name and data come back in the search, including the "lines" that the particular person carries, we would like to be able to click on the "lines" and it will search further specific to that "line". This second search will be pulled from the same table as the first search, it is along the lines of a detailed search versus just a persons name.
Hope this makes sense, we would greatly appreciate any assistance.
The results page created by DataAssist will automatically fulfill requirements 1 and 2.
You will just need to modify the table that is created to display the results.
Select the table tag in the tag selector for the table that you have created to display the results, then go to the server behaviors panel. Click the plus button and select Repeat region. Select the data assist recordset from the list of record sets and set the number of results to return.
