do i need dataassist and css form builder
Thread began 2/03/2010 1:13 pm by kattyblink341141 | Last modified 2/03/2010 4:19 pm by Jimmy Wu | 662 views | 2 replies |
kattyblink341141
Hi I have a question. I have user registartion software and I think I need dataassist in order to edit and make it functional right? I also want to add new fields in the user registration, do I then also need css form builder or can I just use dreamweaver.
neilo
It'd be a lot quicker and easier using Dreamweaver's form options for adding form fields.
DataAssist would be excellent for new, or changing/building-upon existing web applications. There is also a complete User Registration Solution Pack - which is pre-built and ready to go.
Jimmy Wu
If you already have the user registration solution pack, you will not need DataAssist to make the solution pack functional. If you want to edit the page to insert other fields into the registration page, DataAssist would be helpful with that.
