Process type
i am using menu writer for the first time. It opened, i set up a menu and then clicked finish. Got this error message. "Process type "CSS Menu Writer not found". any clues as to what I am doing wrong?
try deleting the Dreamweaver cache file from the users configuration folder:
If you still have the same problem, can you send a screen shot of the error.
