insert client problems
Thread began 2/01/2010 3:24 pm by mr hankey | Last modified 2/08/2010 4:56 pm by Eric Mittman | 1877 views | 7 replies |
mr hankey
hi,
i am sure i have covered this before but i am having trouble with it:
i have a users tbl and client tbl
in client tbl i have a column users_clients which is foreign key between the 2
i have made this hidden in my insert page, i want it to auto associate with the user who has logged in that has added the client. How would i do this, as i then want to display that users results only in the results page.
so that user can only see his own and no one elses. hope you can help, i am trying to think is it to do with binding a session variable from the login page to this page and if so could you just walk me through the steps please?
many thanks
On your login page you should have the Authenticate user server behavior. In here you need to make sure that you are storing the UserID in a session variable.
Once you have done that you can then reference this session variable for the userID in your inserts. You just select the UserID session variable as the value for your users_clients column using the lightning bolt.
mr hankey
hi eric,
i managed to get it working using the session variable from login page, however when you go to the clients details it shows assigned to "1" instead of the users name, how can i change it to show the username for that userid?
i also want it to only show the users clients not everyones. however administrator should see all if possible?
many thanks
In order to get the id to update to be the username you will need to have a recordset that selects from your users table where the userID is equal to the recordset value on this details page. When you have the recordset on the page that is filtered on this user id you can use the user name binding in place of the id value that is present.
If you want to limit the records that are seen to only the user that is logged in you will need to filter on the session userID value you used in the insert. If you want the admin to see all of the records then you will either need to make a separate results page for the admin or add in another recordset to the current results page, then use an if statement to use one or the other. I think it would be easiest to make an admin all users results page that does not filter on the userID.
mr hankey
what about security assist access levels? could this be used here and how?
again eric, many thanks
Depending on how you have your rules setup you could make use of the Security Assist show region. You need to have your rules setup so that your admin is not also a user otherwise both recordsets would exist on the page if you were an admin and this would cause problems.
If you have the rules setup like this then you can add both the filtered and non filtered recordset onto the page and use the show region to have one show only for admin users (the non filtered one) and the other show for the regular users.
mr hankey
hi eric,
can you give me some detiled instructions on how to achieve showing username instead of userid.
i tested it with 1 account and it worked no problem, added a second user and they added a client and it showed still in the assigned to box as my username and not theres?
can you help where i am going wrong with this?
many thanks
What are you currently doing on this page to associate the user with the client? If you are ensuring that the user must be logged in first and that the userID is held in a session variable then you should be using this session variable when inserting a client.
Please describe what you are doing on this page and how you are associating the id. Also, in the db what is the value that is held in these records for the user and client? Please also post back with a copy of the page in question so it can be reviewed.
