Missing drop down menu items
Thread began 1/23/2010 4:30 pm by nickj | Last modified 1/24/2010 7:39 pm by anonymous | 1155 views | 3 replies |
nickj
I've built a menu which displays the top level correctly but fails to display the drop down.
Any help would be appreciated..
Nick
Archive.zip
anonymous
Nick,
You might want to attach the code from the page it resides in too. My guess is that your Menu Writer code is fine but the page or pages it is on may have a problem.
I recently found a similar issue when I had my menu inside a div tag which had the css property for overflow set to "hidden." Naturally, my first suggestion is that you check your HTML and CSS on the pages that contain the menu.
Best regards,
Brian
nickj
here is a page with the menu on it. The problem may be that I am trying to have both the top and secondary levels of the menu dynamic.
test.php.zip
anonymous
Hey Nick,
In the code, I see where you have two separate menus, now:
<div id="tmenu">
<?php require_once("CSSMenuWriter/cssmw0/menu.php"); ?>
</div>
<div id="bmenu">
<?php require_once("CSSMenuWriter/cssmw/menu.php"); ?>
</div>
Have you tried removing, say, the bottom menu just to see if the top one would work? I would start by taking one out to see if it is, in fact, the other one causing the problem. Once we determine that, it will be easier to hunt down what is going on.
My suspicion is that that each CSS menu writer instance has a Z-index set high enough that may cause an issue with the other.
Let me know what happens when you take a menu out and then try it.
Best regards,
Brian
