Changing page type in SiteAssist Professional
Thread began 1/22/2010 10:44 pm by nosakelly1398725 | Last modified 1/25/2010 1:15 pm by Jimmy Wu | 1107 views | 4 replies |
nosakelly1398725
Hello, I am following this tutorial in siteAssist Pro. But can't find "Modify SiteAssist Professional site" From the Modify menu in DW. Only "New SiteAssist professional site option" exist there.
Do I have to reinstall this extension or can someone tell me if there is fix for this.
Thanks.
neilo
Hiya nosakelly,
It isn't in the DreamWeaver 'Modify' menu, but (hopefully) under the 'Site' menu. Post back if it isn't!
nosakelly1398725
Thanks Neilo
It wasn't there either. I just went ahead and used the new site option to practice on another page and then site assist did some shaking & rumbling and then came up the modify option. Oh well! maybe because I just got these things 4 days ago, they need to wake up or something. Though I have noticed that things seem to freeze a lot. Hopefully It won't be frustrating to use.
Office Guy-172461
It shouldn't be freezing. One thing that helps prevent problems like this is to always delete previous versions before installing a new one, and deleting the cache file after installing each extension. This forces DW to update.
You might want to delete the cache now. See step 1:
Solving problems with Dreamweaver
146/
Jimmy Wu
The Modify menu item may not have appeared because it did not recognize the site as part of a SiteAssist made site. Hopefully you do not run into this issue in the future.
If it is just taking a little time to load or perform some tasks, that shouldn't be a problem. If there are any freezing that causes the program to stop working, please post a new thread and we can take a look into the issue with you.
