database not updating + asp session not ending
Thread began 1/22/2010 7:09 am by m_jelly386415 | Last modified 1/22/2010 1:04 pm by Jason Byrnes | 610 views | 1 replies |
m_jelly386415
Attached is my confirm.asp - I've told it to update the customer details table and the Sales detail table, but its only making changes to Customers.
I also want it to use the CustomerID autonumber from Customers and insert it into Sales at the same time, but not sure how to go about that.
Little help?
My sessions are also not ending after reaching the checkout_success page - I tried putting in that php code that is used in other people's session problems, but it had no effect, assuming because I'm using asp and its ignoring it.
confirm.zip
The second insert is set to use the Name, ID and price hidden form elements, do these actually have a value when the form is submitted, you can double check by viewing the source of the confirm page before submitting it.
Instead of using the Dreamweaver Insert Record behaviors to store the order information, you will get better results using the eCart store order summary and store order details behaviors.
in eCart 5, you can use the checkout wizard to create the checkout pages and simplify the process of setting up the order management. It will also handle the storing the customer number in the orders table for you.
In asp the code to destroy a session is:
<% Session.Abandon(); %>
add that after the </html> tag in the checkout success page.
