Validation only Documentation?
Hello,
Is there any documentation for using the validation tools only from the CSS Form Builder Extension? i.e. I do not want to use the CSS form creation -just the validation.
Thanks,
Andrew
Hello,
Thanks,
Andrew
In the validation application wizards, you can click on the help button to look up anything that you have questions on.
You can also go to the Validation toolkit support page, since these behaviors run the same as validation toolkit, but only for PHP:
validation-toolkit/
Unfortunately the Validation Toolkit Getting Started PDF seems to be gone as I get a 404 error when I click on the link.
validation_toolkit_gsg.pdf
Thank you for pointing this out. I will bring this to the attention of the site administration team and get this up and running.
Please check back tomorrow and the link should be fixed.
Andrew,
The Getting Started Guide can be found here:
The link on the support page should be fixed shortly.
