Newbie Question - Error Message
Thread began 1/20/2010 8:02 pm by david323147 | Last modified 1/21/2010 1:21 pm by david323147 | 754 views | 3 replies |
david323147
I know I must be missing something basic here.
I've created a database and table called 2010products (see the accompanying pdf showing my table). All fields are VARCHAR.
I've done the Data Assist wizard several times and when I'm done and test it I continually get the following error message on my results page - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'FROM 2010products LIMIT 0, 1000' at line 1.
What am I missing?
Thanks!
products.pdf
Hervé
Originally Said By: david323147
What am I missing?
Thanks!
Check field names your are using, avoid - (minus sign) usage
regards
Also avoid using spaces in the Column names.
if you continue to have problems, please post a copy of your page so we can see the SQL code that is generating the error.
david323147
Thanks. I had a space in one. That was the problem.
