Security using CSS form builder
Thread began 1/19/2010 6:45 pm by Wasntme | Last modified 1/25/2010 7:24 pm by Eric Mittman | 1059 views | 5 replies |
Wasntme
I have used CSS FB to build a contact form but i still get spam coming through.
I currently only use the captcha but I notice on the solution package you have used some hidden ones to keep the spam out. Could you please explain a little more on the hidden security so I dont get spam please.
Thank You.
For securing your forms there is the CAPTCHA, security questions and some empty hidden form elements.
The idea with the hidden form elements is that you leave them blank and validate for them to be blank, if they have a value they should fail validation. The idea is that a bot filling in the form will fill in these hidden form fields as well, so if you confirm that the fields have no value in them it is more likely that a real human filled in the form.
If you put the Universal Email server behavior on the page yourself you should check it to make sure you have it set to same page post as the trigger, this can help with things also.
Wasntme
Hidden
Ok, So when I am building the form with formbuild I should place few hidden validation is that correct? if so would i also need to tick the validation required field and what should i place in " RegEx"? Thank you so much for helping..
I was wrong in how I described these fields, they are actually set as type="text" not hidden, but the other details are the same.
Here is an example of what one of these fields looks like in the form:
html:
<input name="addblock" id="addblock" type="text" style="display:none" value="" />
You would then want to add in a regular expression type of validation, check the box for allow blank then use this regex:
/^$/i
In the User Registration Solution Pack there are two of these text fields each with their own validation.
Wasntme
Thank you. I will test this and let you know.
Just FYI for you or anyone else that comes across this, the regular expression used is trying to match on a blank value, in case you were wondering.
