Error "In file WA_SiteTools_Progress
Thread began 1/18/2010 5:20 pm by Ben Pleysier | Last modified 1/22/2010 1:44 pm by Jimmy Wu | 2709 views | 7 replies |
Ben Pleysier
After having used Site Import a couple of times in the past, I now get an error as shown in the attachment.
I have delete the win cache file a couple of times and uninstalled/reinstalled the extension but to no avail.
Please help.
Ben
Ben Pleysier
Delete win cache once again, this time with Dreamweaver closed and it worked.
Yes, it is important to have Dreamweaver Closed when deleting the cache file.
Yazzy
no luck
I have still the same issue ...
deleted the wincache file with dreamweaver closed. with no luck.
de-installed + deleted the wincache file again with dreamweaver closed
re-installed + deleted the wincache file again with dreamweaver closed
nothing makes those error messqges go awy.
even when the extension is completely removed.
any other suggestions ?
In Dreamweaver go to Window -> Workspace Layouts -> Rename '<Your Layout Name>'
then close dreamweaver, delete the cache file and restart the computer.
Yazzy
not yet
Many thanks for your suggestion ... unfortunately it didn't do the trick.
Did exactly what you requested, but no luck.
the extension is removed completely now, but error messages are still there.
Any other suggestions ?
Yazzy
is there a way to clean up dreamweaver manually ?
the extension is already removed, but the error messages are still there.
thanks
Jimmy Wu
I sent you instructions on how to clean up the extensions by renaming the configuration folder in a backend ticket.
