Reformat Computer: eCart doesn't work...
Thread began 1/18/2010 5:36 am by victor278184 | Last modified 1/18/2010 2:37 pm by Jason Byrnes | 861 views | 2 replies |
victor278184
Hello,
i just reformat my computer, reinstall all WA extenstion.. now eCart suddenly doesn't work.. it returns error like this:
At line 907 of file "I:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Commands\WA eCart AddToCart.js":
document.generalWP.document.column.options[document.generalWP.document.column.selectedIndex] has no properties
does this error happen because of i reinstall WA extension at once ??
Office Guy-172461
Have a look at this thread:
showpost.php?p=38784&postcount=2
This can sometimes occur when adding an add to cart button and using the Lookup Item ID from recordset option when the recordset has an Order By clause.
If you are using a recordset with an Order By clause, try removing it temporarily, then adding the add to cart button. You can replace the order by clause after the add to cart button has been added to the page.
