cms menu error
Please am having these error starting up when I start dreamweaver, and I've tried to reinstall css menu write, but still the same problem.
thanks
thanks
Have you tried deleting the cache file? Please follow the directions for deleting this file here:
If the issue persist then there may be a corruption of your configuration folder. If this is the case you will need to rename this folder to get things working. Here is a link to the instructions for doing this:
showpost.php?p=12293&postcount=2
I followed
Dreamweaver CS3 /users/[username]/Library/Application Support/Adobe/Dreamweaver 9/Configuration/
it's not there
Dreamweaver CS3 C:users/[username]/AppData/Roaming/Adobe/Dreamweaver 9
I cant locate it there as well.
The only place that I could find it C:/Program files/Adode/Dreamweaver cs3, and when I deleted the cofiguration file under it, and restart dreamweaver, it says configuration files cant be found reinstall dreamweaver.
I've also reinstall cssmenu writer but still tthe same
Type
%appdata%
In to the address bar of My Computer, or Windows Explorer. (or the Start > search [Vista] Start > Run [XP] box)
This will bring you to the 'Roaming' folder under which you should then click on 'Adobe' then 'Dreamwever9' - and that should show you your configuration folder.
The full path is:
[Vista]
C:\Users\your_user_name\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
[Windows XP]
C:\Users\Neil\Application Data\Roaming\Adobe\Dreamweaver 9\Configuration
Not sure what a Mac path would be, but %appdata% will get you most of the way there.
