SiteAssist Professional Wizard - Error on Site Types
Thread began 1/10/2010 8:20 pm by msdesign1388986 | Last modified 1/11/2010 1:42 pm by Jimmy Wu | 1040 views | 2 replies |
msdesign1388986
Hello! I'm using the SiteAssist Professional Wizard to create a new site. On step 5 I have chosen "Create new site type" w/name "ecptemplate". I am getting the following error when I tap 'finish' ..."The following errors were found: -Site type name must be unique" w/the only option of "ok" (note: the placeholder content is set to "Full" w/"include CSS comments" checked and doctype: "HTML 4.01 Transitional".) I've tried naming it several different names and receive the same error message. Any and all advice ASAP would be gratefully appreciated as I do not want to lose the stuff I've done so far...Thank you!
msdesign1388986
ok...I simply exited out of the wizard (didn't hit cancel or anything, just the 'x') and shut DW down & reopened it. Reopened the wizard & it had saved my settings, so I checked it out & everything was still correct, then I put in the template name (it hadn't saved that) and hit finish - and it worked! There must've been a glitch or something...
Jimmy Wu
Glad you were able to get this working without losing the work you had done previously. If you run into any additional issues, feel free to open a new thread.
