Database showing ID values not Text Labels
Thread began 1/10/2010 2:28 pm by walt125013 | Last modified 1/11/2010 10:40 am by Jason Byrnes | 1463 views | 3 replies |
walt125013
This is probably a basic and simple question, but when I am using a seperate table to display values in my database I need it to show the text column not the column ID. For Instance:
I have a table of musical artists and then a seperate table with the artist Genres. The Genres table has a genreID column and a genre column, i.e. genreID = 1, genre = Pop/Rock
How do I get my database to show the Pop/Rock text in a web page instead of the number "1" when I am using the genre table as a relationship to populate a dynamic drop down?
I have a feeling this was poorly explained and way confusing...
Sorry! But this seems like it would be a common issue!
bgw1999373018
I am having the same type of issue. I started a thread in the Dynamic Dropdowns forum ;-)
walt125013
what is the title of your thread?
I want to find this out ASAP!
You need to modify the recordset to use a joined query to return the data from both tables. With out knowing the structure of both tables I cannot give the exact syntax to use, have a look at the following on the w3schools site for information on join queries:
sql_join_inner.asp
NOTE: bgw1999373018, your issue is a bit different since you are trying to get the labels from a select list. Your solution will not be applicable here.
