Unable to find file WA_SiteTools.htm
Thread began 1/07/2010 9:13 am by jim.anderson395726 | Last modified 1/07/2010 10:11 am by Jimmy Wu | 1324 views | 1 replies |
jim.anderson395726
After having deactivated all the WA extensions, everytime I launch Dreamweaver (CS4 on Mac OS 10.6.2) I get the following message:
Unable to find file WA_SiteTools.htm in the Configuration/Floaters directory. The floater will not be shown.
What should I do to get rid of that alert box?
Jim
Jimmy Wu
You can rename the configuration folder, which will have the effect of disabling all of your extensions that are still installed. It should also remove that popup. Here are some steps you can take to do that:
showpost.php?p=12293&postcount=2
