Can't get the Security assist wizard to work
Thread began 1/06/2010 9:42 am by wschaepe397797 | Last modified 1/08/2010 10:01 am by Jason Byrnes | 1563 views | 6 replies |
wschaepe397797
I am trying to create a login page only.
When I select a DW template (jpg #1)that that I use for the pages, and then select the file I want to go to when successful, it tells me that first that to make a document-relative path, I need to save the document- But I am not done yet. Then if I click on the okay, I get the following message (jpg #2) that the file you have chosen is NOT based upon your selected template and it tells me to chose another file or a different template. It is template based (But in fact the file I have chosen IS based upon my selected template- A_AC-Layout-Mater-2-one_col!!). It will not select the file to go to if successful or the file to go to if login fails.
Then if I try to NOT select a template (jpg #3), and proceed, I get error message (jpg #4) and it tells me that the page I selected is based on the template (that I selected in the first place). In order to chose this page, select the template and an editable region.
So I can't make it work either way. So what do I do??
I just purchased this software because the Adobe Developer toolkit does not work anymore.
is the page you are selecting open in Dreamweaver? is it a new page that has not been saved yet?
I could see if the template where applied to the page, and the page was not saved before running the Security Assist wizard it would generate that error.
wschaepe397797
reply
The page (beneifts.php) was saved and was not open.
wschaepe397797
If this can't be made to work I would like a refund
If the web assist software can't be made to work, I would like a full refund and I will remove the software from my computer.
In the meantime, I'll just use PHP code to develop the user login form.
Please let me know if this problem can be solved and if not when you will refund my money!
Regards,
Bill Schaepe
Instead of selecting a file to goto after login, type in the name of a file that does not already exist, The template will automatically be applied to the page.
wschaepe397797
Okay that works but know I get the following errors
I had to save the two .php files I want you to look at as .txt files since I can't upload php files
If you look at members_LogIn_1.php(.txt) you will see that the PHP stuff at the top is missing some <?php and ?> tags. This may be my Dreamweaver doing it. So I added the tags in members_LogIn_2.php(.txt) and I get the following parsing error:
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ']' in C:\xampp\htdocs\CUCNY_CSS\members_LogIn_2.php on line 182. Somewhere around line 182 I am missing a "]".
Can you look and see where it should go?
Regards,
Bill Schaepe
members_LogIn_1.txt
members_LogIn_2.txt
There is definitely missing code on the login page. I have never seen the security assist wizard generate a login page like this before.
from line 1 to the doctype tag, the code should look like:
<?php require_once('Connections/columbj7_members.php');?>
require_once( "WA_SecurityAssist/Helper_PHP.php" );?>
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $columbj7_members,
"database" => $database_columbj7_members,
"tableName" => "members",
"columns" => explode($WA_Auth_Separator,"Lname".$WA_Auth_Separator."ACCOUNT_"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"")  ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"")  .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"ACCOUNT_"),
"sessionNames" => explode($WA_Auth_Separator,"ACCOUNT_"),
"successRedirect" => "login_benny.php",
"failRedirect" => "login_brnny_not.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
To send PHP pages, you can compress them into a zip archive and attach the zip file to your message.
