Multiple Locations on Maps Dimmed out with ColdFusion 8
Thread began 1/06/2010 6:00 am by georgemurphy357454 | Last modified 1/06/2010 9:24 am by Jason Byrnes | 1438 views | 2 replies |
georgemurphy357454
I have an issue with trying to add dynamic multiple map locations from a recordset. The Show Multiple checkbox is always dimmed out. I am using the latest version of the Google Map extension and Dreamweaver CS3 and ColdFusion 8. I am not able to add multiple map locations. This is why I bought this extension plus I did read that ColdFusion was one of the supported languages.
georgemurphy357454
Solved Problem
In order to not have the multiple locations option dimmed out the recordset has to exist on the page before you try and insert a Goole Map.
Yes, that is correct, the multiple locations option is only for use with recordsets.
If you are adding the addresses manually, you do not need to use that option. If you are using a recordset though, choosing that option causes it to loop through all of the records in the recordset. If you do not select that option, it will only return the first record in the recordset.
